Ignition Key Problem 2009 Nightster
Ok, this is a really stupid problem. I moved my coil and key switch to the left side of the bike. they are now mounted to a bracket which is mounted to the rocker boxes. after putting some miles on the bike, i think the tumblers in the key switch are f*cked up. i cant remove my key from the switch and when i am riding into the higher rpms, the bikes cuts on and off. i believe the vibration got to it. the crazy thing is, i can still turn the bike on and off with the key....i am just wondering how can i just get rid of the key switch completly and hide a toggle switch somewhere on the bike. if anyone could help, that would be greatly appreciated.
Hmmm.......jiggle, jiggle, jiggle. If/when you get the key out try using some graphite (get it in the key section at Home Depot). The problem sounds more like a wiring then a mechanical problem but...??? Just be sure to check the wiring connections to make sure. When I relocated my coil I cut the bracket and left the key in the stock location specifically because I was worried about the vibration between the cylinders.
haha, gotta do what you gotta do. It really is embarassing not being able to get the key out of the ign. some times. I can only get it out with my right hand, if i try to REMOVE THE KEY with my left, it wont come out haha. Now if bold part wasnt there, THAT would sound dirty.
Oh and i have been to the dealer about this, The man behind the counter at service claimed to have "never seen that before".
