help about riser and tank lift
Old 01-11-2011, 08:09 AM
reddust's Avatar
reddust
reddust is offline
Default help about riser and tank lift
if i install 2 inch tank lift kit and 4 inch straight riser to my iron 883 (2010),
would the handlebar hit the gas tank ???
any idea or picture about it ?????
Old 01-11-2011, 10:10 AM
Steeler's Avatar
Steeler
Steeler is offline
Default howzit
On the Nightster I lifted mine about 3 inches and didn't use risers no problem it does depend on the amount of bend on the bar I've only got a 30 deg bend.
Old 01-11-2011, 10:26 AM
snacks63's Avatar
snacks63
snacks63 is offline
i have some 4'' joker machine risers for sale 80bucks shipped if your interested black anodized ones
Old 01-11-2011, 01:22 PM
reddust's Avatar
reddust
reddust is offline
i am gonna use stock handlebars
Old 01-11-2011, 05:47 PM
streetfighter06's Avatar
streetfighter06
streetfighter06 is offline
This is simple mathematics. Reread your question and you will be able to answer it on your own.
Old 01-12-2011, 03:34 AM
reddust's Avatar
reddust
reddust is offline
lol my math is really bad , pls enlighten me ...
Old 01-12-2011, 03:38 AM
Guest
Guest
Posts: n/a
No, it won't hit.
Old 01-12-2011, 06:11 AM
xFreebirdx's Avatar
xFreebirdx
xFreebirdx is offline
Originally Posted by tekdiver500ft
No, it won't hit.
+1....
Old 01-13-2011, 04:30 AM
reddust's Avatar
reddust
reddust is offline
thnx a lot everyone.
Old 01-13-2011, 06:24 AM
schwingding's Avatar
schwingding
schwingding is offline
No, it won't - how are you lifting your tank? There are a lot of pricey kits out there, but all you need is to buy 2 U bolt assemblies with a 2" spread, discard the bolt and paint the sheet metal piece black - those are your risers - $4 total, add a few nuts and bolts that you probably already have lying around and you're good to go, for less than a bowl of soup.
While you're under there, lift the tank up as far as you can and look around, then unhook the gas line (it is a quick disconnect), and flip the tank all the way up - look around again because you're soon going to want to relocate your coil and ignition as most of us have, and you'll get to know the wiring. Then after you relocate the coil, you're going to want to remove most of the plastic housing assembly between where the coil was and the frame to clean things up. Then.... then....then....
Quick Reply: help about riser and tank lift
