Need advice on 2001 883 sportster
Hi all,
Just got a 2001 HD 883 Sportster. I don't have a owners manual and had my first mishap by running out of gas. I know it's a dumb question, but can someone tell me which direction the reserve tank switch should be positioned? And should I switch it to off when I'm not riding?
So what is the correct direction of this area? If I'm looking at it straight on. Is the OFF switch on the left, ON swich at the top and the Res on the right? I'm just confused which part of the petcock should be pointing. Right now I have the petcock in the north and sound position with the bigger portion of the petcock pointed down and the nipple part facing north. Hope this make sense.
There will be a small (tiny) arrow on one end of the petcock lever. The older levers had the long end towards what you want & the newer ones had the short end. I can completely see why it's confusing but look for that arrow.
If you have a small vacuum line on the backside of your petcock you don't need to shut it off.
