HELP - Harley Shop can't figure out my problem
Old 03-29-2017, 08:25 PM
adamk's Avatar
adamk
adamk is offline
Angry HELP - Harley Shop can't figure out my problem
The Harley shop has been working on my 2000 Sportster for 6 hours and still doesn't have a clue what's wrong.
Here's the details:
A few weeks ago after a light rain, my bike started up fine, but it had _zero_ torque. Whenever I started releasing the clutch and giving it gas, the bike would lose power instead of gaining power, and start dying. The only way I could get the 1/2 mile home was to leave the clutch half-way in and limp home.
I tried fixing it myself first by just spraying some carb cleaner in the carb. Then I put some seafoam in the gas tank. Then I began dissassembling and cleaning the carb. When I found some gas lines that seemed to be disintegrating, I had it towed to the Harley shop to replace all of the fuel lines.
* They cleaned, and replaced parts of, and re-installed the carb.
* They said the gas lines that were going bad were just vent lines and they were fine. They also "trimmed" some gas lines.
* The compression is good.
* The leak down is good.
* The spark plugs are getting clogged but this doesn't seem to be the source of the problem.
* They told me that the cam sensor on these bikes tends to go bad and need to be replaced, but that my problems are not indicative of that issue.
They're completely stumped, and neither they nor me are thrilled with them spinning their wheels for another 10 hours trying to track down this problem.
Any ideas??
Old 03-29-2017, 08:30 PM
MURPHCC1's Avatar
MURPHCC1
MURPHCC1 is offline
Received 2,791 Likes on 1,359 Posts
so......it idles fine?
in neutral, it revs up ok?
They both sound normal?
Old 03-29-2017, 08:39 PM
Taggs's Avatar
Taggs
Taggs is offline
Not having the shop manual in front of me for your year bike, just first guess it could be a ignition timing module bad or even possibly the connection at that module. It's located under the seat.
Jaystn62's Avatar
Jaystn62
Jaystn62 is offline
Spark plugs are getting clogged? Fouled?
Old 03-29-2017, 08:43 PM
adamk's Avatar
adamk
adamk is offline
Yeah. This has never been a problem before and new plugs don't solve the main problem.
I suspect this is related to cleaners that I used and will disappear should they dump the tank and give it new fuel.
Old 03-29-2017, 08:46 PM
adamk's Avatar
adamk
adamk is offline
I don't have the bike with me, but if I recall it idles okay if not perfectly.
Oh... I didn't mention this above, but after limping along for a while trying to get it to a garage I could use... I was unable to get it started again.
That's when I started pulling apart the carb.
Old 03-29-2017, 08:52 PM
adamk's Avatar
adamk
adamk is offline
I'm going to be really, really nice here and not mention which Harley shop this was.
They just called back. They found some pin that's a part of the carb sitting there on the work bench that they forgot to install.
They installed it and now it seems to be running just fine.
Old 03-29-2017, 08:59 PM
Lonnie Mac's Avatar
Lonnie Mac
Lonnie Mac is offline
They just called back. They found some pin that's a part of the carb sitting there on the work bench that they forget to install.
Needle jet. Either sitting on some one's workbench, or rolling on the floor! It's a very elusive little part. Get's em every time.
Old 03-29-2017, 09:03 PM
MURPHCC1's Avatar
MURPHCC1
MURPHCC1 is offline
good for you!!
Old 03-30-2017, 08:07 AM
Triumph Jerry's Avatar
Triumph Jerry
Triumph Jerry is offline
Can't believe the shop admitted their mistake, must be an honest shop.
TStephen (03-30-2017)
Quick Reply: HELP - Harley Shop can't figure out my problem
