HELP - Harley Shop can't figure out my problem
Here's the details:
A few weeks ago after a light rain, my bike started up fine, but it had _zero_ torque. Whenever I started releasing the clutch and giving it gas, the bike would lose power instead of gaining power, and start dying. The only way I could get the 1/2 mile home was to leave the clutch half-way in and limp home.
I tried fixing it myself first by just spraying some carb cleaner in the carb. Then I put some seafoam in the gas tank. Then I began dissassembling and cleaning the carb. When I found some gas lines that seemed to be disintegrating, I had it towed to the Harley shop to replace all of the fuel lines.
* They cleaned, and replaced parts of, and re-installed the carb.
* They said the gas lines that were going bad were just vent lines and they were fine. They also "trimmed" some gas lines.
* The compression is good.
* The leak down is good.
* The spark plugs are getting clogged but this doesn't seem to be the source of the problem.
* They told me that the cam sensor on these bikes tends to go bad and need to be replaced, but that my problems are not indicative of that issue.
They're completely stumped, and neither they nor me are thrilled with them spinning their wheels for another 10 hours trying to track down this problem.
Any ideas??
I suspect this is related to cleaners that I used and will disappear should they dump the tank and give it new fuel.
Oh... I didn't mention this above, but after limping along for a while trying to get it to a garage I could use... I was unable to get it started again.
That's when I started pulling apart the carb.
They just called back. They found some pin that's a part of the carb sitting there on the work bench that they forgot to install.
They installed it and now it seems to be running just fine.
They just called back. They found some pin that's a part of the carb sitting there on the work bench that they forget to install.
