My left mirror on my '08 nightster keeps moving due to the vibration on the bike. It doesn't look like there's any way to tighten it. Are there any tricks to keep it in place or do I have to buy new ones?
If it's the mirror moving on the ball there isn't much you can do to tighten it. You can try a small drop of loctite where the ball meets the socket, run it around with a toothpick or something then wipe it off.
It's a cheap fix. I find I have to re-do my left one every few months or so when it gets bumped hard.
Thanks!
new super glue gel that contains rubber. 10k miles and still tight. the rubber compound still allows adjustment
ok, here's the correct product name:
gorilla super glue, impact tough formula
Thanks for the input....we'll try either the loctite or the gorilla glue and see how things go. I still want to be able to adjust my mirror when needed.
