Getting only 35 miles per gallon on my 883 :(
Old 03-18-2011, 02:19 PM
harlot's Avatar
harlot
harlot is offline
Default Getting only 35 miles per gallon on my 883 :(
So I just bought an 05 883 on monday, and I filled it up two days ago, cleared the trip odometer, and today I cleaned out my tank, it recorded 113.6 miles, and so if I divide 113.6/3.3, it's about 35 mpg.
is that normal? Cos I see on websites it says 883 gets like 45 mpg even on street roads.
i know the guy had drag specialities slip ons added, as well as a KnN filter.
no other mods, can someone tell me if this is normal?
thanks!
Old 03-18-2011, 02:40 PM
twisty571's Avatar
twisty571
twisty571 is offline
I have a complete Stage 1 done and I get 45-55 gallon,that also depends on how much idle time and reving your doing or hard accelerations or 2 up riding.....how does it run?
Old 03-18-2011, 02:54 PM
Bombn's Avatar
Bombn
Bombn is offline
6th Gear
3.3 gallon take has a 1/2 gallon reserve and the fuel pump takes about another 1/2 gallon, so if you run it empty you can only fill it with about 2.3 gallons. 2.3 / 113.6 = 49 mpg = about what you would expect.
How much did you get in tank?
Old 03-18-2011, 02:59 PM
DannyZ71's Avatar
DannyZ71
DannyZ71 is offline
Yeah, take your mileage and how much gas you actually put back in to figure it out. Not the tank capacity.
(side note: I thought fuel injected bikes didn't have reserve gas. 05 not injected? )
Old 03-18-2011, 03:08 PM
harlot's Avatar
harlot
harlot is offline
05 is carb, and I put in 3.32gal today. yep!
I don't understand what do u mean by how does it run. can u explain and maybe I'll know what u meant? I'm still learning the terms right now
hmm I've ridden 2 up for like a total of 10 mins, and I ride streets only since I'm a new rider. Rev it now and then to get a feel of the bike, I usually cruise in 3rd gear. havent gotten to 5th yet.
so yea, I believe I've divided the fuel to milege correctly. which does put me at arnd 34-35 mpg.
Old 03-18-2011, 03:09 PM
harlot's Avatar
harlot
harlot is offline
it's a 883 custom so the tank looks like yours, twisty
Old 03-18-2011, 03:13 PM
streetfighter06's Avatar
streetfighter06
streetfighter06 is offline
You cruise in 3rd gear? Why?
My bike had exhaust only and sometimes I got 40 mpg, sometimes almost 50 mpg.
Old 03-18-2011, 03:17 PM
DannyZ71's Avatar
DannyZ71
DannyZ71 is offline
How does it run? Is it smooth at idle? Does it accellerate smoothly? Does it pop and ping?
I think this is your problem. Your best mileage is gonna come out on the highway at a steady speed, and in 5th gear. Cruising the back streets in 3rd gear, I'd say you're getting really good mileage.
twisty571's Avatar
twisty571
then you have the 4.5 gallon tank and as far as running I mean when you hit the throttle does it pop or backfire alot or seem like it is starving? Have you checked your spark plugs? Better spark burns it better. Are you getting a strong fuel smell from your carb? Smooth acceleration thru the gears? I know when I am running the mountains around here I get worse mileage but that is to be expected,harder throttle and higher reving & 2 up riding.
Old 03-18-2011, 03:18 PM
harlot's Avatar
harlot
harlot is offline
cos I don't go over 40, limit in my town is 45, and I mean, I'm still new, and getting to know riding my bike
Quick Reply: Getting only 35 miles per gallon on my 883 :(
