Owners of Sportster 1200 with pipes, help!!
Old 04-29-2011, 03:56 PM
bwatte's Avatar
bwatte
bwatte is offline
6th Gear
Default Owners of Sportster 1200 with pipes, help!!
Ok I have a sportster 48 1200, I am putting the big sucker kit on along with the short shots. My question for you guys is if you like the Harley download remap or the fuel pack?
I was wondering if the remap is good enough or if I should just go with the Vance and Hines fuel pack.
Thanks
Old 04-29-2011, 04:59 PM
Osco's Avatar
Osco
Osco is offline
Account Deactivated
Cool
You Get wgat you pay for,,
The HD sert without dyno time will be close,,hopefully close enuff,,
The V&H uses Base maps they created,,It will be close,,hopefully close enuff,,,
The V&H fuel pack's maps are not adjustable so dyno time would not help much.
This should make ya safe,,
http://www.nightrider.com/
http://www.nightrider.com/parts/
READ THE FAQ page,,,
PCV Is better still,,
ThunderMax Is top shelf but BIG Bucks,,a bit over kill for us normal guys.
Old 04-29-2011, 06:00 PM
Aaron48's Avatar
Aaron48
Aaron48 is offline
I have Bassani Fire Sweeps, Ness Stage 2 AC, and a V&H Fuel Pack its runs perfectly and hauls ***. As Osco Stated you get what you pay for and for the money the fuel pack is great. For how I ride and what I ride its perfect.
Old 04-30-2011, 08:11 AM
Hawg295's Avatar
Hawg295
Hawg295 is offline
I have the PCIII. An Indy did a Dyno on it, then I tweaked the fuel cells using the laptop. I got rid of the de-cel pop. After 7,000 miles it still runs great.
Old 04-30-2011, 08:47 AM
dp2826's Avatar
dp2826
dp2826 is offline
I went with PCV from fuel moto. They load a map for your setup. So I can change or dyno if I choose later. The bike runs so much better, and the oil temp gauge is down a good 20 degrees. I was also looking at the nigtrider xieds or one of their products. I would go with those over a dealer download personally. From the info I gathered here on the forum the download is still lean due to emissions or legal crap.
Old 04-30-2011, 10:04 AM
rob m's Avatar
rob m
rob m is offline
6th Gear
Not to change you subject, all do respect but, what size is your front rim and tire I think it looks good and im wanting that look
Thanks Rob
Old 04-30-2011, 05:53 PM
wanabe's Avatar
wanabe
wanabe is offline
my fav is on my bike.. Techlusion Fuel Injection Control Module (TFI Fuel management system)
not expensive and easy to adjust the settings, although once I dialed in the current settings I have not had to change them... just perfect-
http://www.dobeckperformance.com/mot...sp?make=harley
should have mentioned that my bike is running V&H pipes and Ness sucker- love the set up.
Old 04-30-2011, 07:55 PM
Rowdy D's Avatar
Rowdy D
Rowdy D is offline
1st Gear
I have the PCV from fuel moto. Bike runs better then ever. Told them i have the V&H Big Radius with a Figure Engineering AC and the map was already loaded ready to go. Couldn't be happier
ber1200c
03-30-2013 01:39 PM
081200C
02-18-2010 11:20 AM
Mikind7
03-29-2008 07:08 PM
bulldogmoe7
06-16-2007 05:47 PM
AR4CE
04-14-2006 11:28 AM
Quick Reply: Owners of Sportster 1200 with pipes, help!!
