I know this has been asked and im sorry! What is the best spark plugs all around.
Old 11-24-2011, 03:18 PM
SportyPig's Avatar
SportyPig
SportyPig is offline
I'm not fighting anybody. Just trying to help people out with a question.
And it's these type attitudes that have driven away the wealth of knowledge that used to be available on this Sporty Section. If I seem a bit chippy from time to time, that is why.
Old 11-24-2011, 06:54 PM
Jackal's Avatar
Jackal
Jackal is offline
Originally Posted by 95th 1200
Put in what the OE suggests. If they call for coppers, putting in double plats will not make more power, increase mpg, or make it run better. They'll just empty your wallet sooner. General rule of thumb regarding plugs;
Champion for Chryslers, HDs, and lawnmowers
Autolite for Ford products
AC Delco for GM products
NGK & Denso for Asian imports and some VWs
Bosch for Euro imports.
Specs change all the time though. For instance my 2000 Silverado use to call for copper gapped @ .060 in the service manual, owner's manual, etc. They have since changed that spec to Iridium gapped @ .040. It definitely idles much better, not sure about the rest.
Old 11-24-2011, 07:43 PM
Bagger Jim's Avatar
Bagger Jim
Bagger Jim is offline
Well, guess I'll weigh in on this. On my Fatboy, I used to run the split electrode Screaming Eagle plugs which I think have been discontinued, and they made a noticeable difference in performance. I switched back and forth with stock plugs several times to confirm, and it always rang true. That said, I just changed from stock Harley plugs to NGK Iridium, and I swear the bike didn't seem as responsive. I'm changing back to OEM plugs this weekend.
Old 11-24-2011, 07:46 PM
Bagger Jim's Avatar
Bagger Jim
Sorry, to clarify, the NGK vs stock plug issue is on my Sporty.
Old 11-27-2011, 01:29 AM
rocketmangb's Avatar
rocketmangb
rocketmangb is offline
I believe in indexing plugs.
Its a pain but only minor,worst part is finding the washers but NRHS sells them
The late Sportster does not have a knock sensor or if it does it is not the ION sensing type as I have a 2012 "48" and it has 6R12's in it factory
I like NGK's and the correct plug is a DCPR7E and they run about 3 bucks each the DCPR7EIX Iridium will run you about 8 bucks each
Old 11-27-2011, 09:28 AM
xwhyz1959's Avatar
xwhyz1959
xwhyz1959 is offline
Received 1,412 Likes on 453 Posts
asahi1234
07-26-2016 03:42 PM
CT-Bagger
08-17-2011 11:30 AM
tenrams
Engine Mechanical Topics
02-05-2011 03:40 PM
laynlow
38
10-07-2007 07:27 PM
corona
Exhaust System Topics
03-05-2007 08:34 PM
Quick Reply: I know this has been asked and im sorry! What is the best spark plugs all around.
