surging problems 2012 V&H 2into2 big radius
hey there i have just brought a new sportster and are having problems with surging at low speed and sometime on the highway to. I have put new V&H 2 into 2 big radius on, a screaming eagle air cleaner and screaming eagle stage 1 round air cleaner and race tuner on and still have a problem anyone got any suggestions on how to fix this problem so I can have a enjoyable ride????
Who did the tune on your bike? Was it a dyno tune or just a map download?
I recognize the symptoms you are describing as I had similar issues.
Mine, however, came from a 1200 upgrade to an 2010 883.
What it came down to was the canned map the dealer tossed on the ECM.
Once I had them throw it on the dyno, all issues went away.
I had my sportster tuned with with the SE super tuner (what replaced the old race tuner) with V&H pipes with no issues. You can run most, if not all, exhaust systems with the tuner.
Unless you get shammed into buying the street tuner which basically only allows you to update with canned maps. Then you'd probably need to stick with the Harley exhaust as that's probably all the make maps for.
