Sidecar on Sportster
Old 05-30-2012, 08:59 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,852 Likes on 2,419 Posts
Lightbulb
Originally Posted by hhkiwi
Here's what I've got so far. Still looking for ideas on how to attach the sidecar's lower mounts to my Sportster.
Is that a new frame, or have you just made a remarkable job of restoring it?
Old 05-30-2012, 11:37 AM
RAL's Avatar
RAL
RAL is offline
http://www.sidecar.com/
Somebody there is bound to have the answer. Once you get her done take a sidecar riders class. Having two wheel experiance and jumping on and riding a hack is more dangerous than having zero expriance on a bike and jumping on.
Looks like it is going to be a sweet setup, be sure and post a photo when shes done!
RAL
Old 05-30-2012, 07:30 PM
hhkiwi's Avatar
hhkiwi
hhkiwi is offline
grbrown, the sidecar is a 2009 model and had only done around 80 miles when I purchased it but I completely took it apart. I thought the frame looked too light for my Sportster so I:
1. reinforced the frame by welding in the diagonal brace;
2. removed the rear lower mount (a clamp-on type bracket) and welded a new mount on;
3. welded in the plate on the right side which also reinforces the swing arm tower;
4. welded on the front part of the frame to align it with the main frame;
5. built a support for the new fender.
In addition, I replaced the axle with one I had made by my local machine shop for the Fatboy wheel. Note that the new axle accommodates a 1" bearing on the inside (where the load is highest) and a 3/4" bearing on the outside. The setup does not require a bearing spacer.
Once I've fabricated my subframe and mounted the sidecar I'll post more photos. It'll probably take me a few weeks though - I'm busy with other stuff at the moment :-(
Old 05-30-2012, 07:36 PM
hhkiwi's Avatar
hhkiwi
hhkiwi is offline
RAL
Thanks RAL, and don't worry - I'll take care. I already got David Hough's book "Driving a Sidecar Outfit" and will go through the exercises before embarking on a longer tour or taking passengers.
Old 05-31-2012, 05:12 AM
grbrown's Avatar
grbrown
grbrown is offline
If the sidecar maker is still around can they supply suitable mounting kit?
Old 06-24-2012, 10:53 PM
hhkiwi's Avatar
hhkiwi
hhkiwi is offline
Here's an update to my Sporty sidecar project.
I ended up making my own subframe for the lower mounts:
... and finally got 'round to attaching my Velorex yesterday:
Happy with the result and my first ride today was great!
Old 06-25-2012, 04:53 AM
grbrown's Avatar
grbrown
grbrown is offline
Talking
Well done, looks great. You really didn't need any help by the look of it!
Old 12-27-2019, 05:07 PM
Francisco Marques's Avatar
Francisco Marques
Francisco Marques is offline
Stage I
Hey! Where did you got that seat from? I've been looking for a seat like that for my sportster with no luck.
Thanks!
Old 12-27-2019, 05:41 PM
rhino1250's Avatar
rhino1250
rhino1250 is offline
Received 1,344 Likes on 615 Posts
Great job
looks awesome
Old 12-27-2019, 07:30 PM
apache snow's Avatar
apache snow
apache snow is offline
Thanks!
2012 thread. He hasn't been on here since 2015.
ManOfIron
11-11-2013 05:31 PM
brettym
Sportster Parts
08-14-2012 10:58 AM
Muddyape
08-11-2012 09:49 AM
AaronG87
12-28-2011 09:07 AM
Tike71
11-20-2010 04:21 PM
Quick Reply: Sidecar on Sportster
