Ignition Module Kits
Old 06-04-2012, 02:09 PM
DocUSMC's Avatar
DocUSMC
DocUSMC is offline
Default Ignition Module Kits
Does anyone have any proven take on these? Mines shot to hell and needs replaced.
The ones I am looking at are:
Daytona Twin Tec
Dyna 2000
Dyna 2000i
Crane Hi-4
The ones I am looking at come in a kit module/coil/wires.... I would also like to know if I should run dual or single fire. Any input by those who have used these would be greatly appreciated!
Old 06-04-2012, 04:58 PM
Zimbob's Avatar
Zimbob
Zimbob is offline
I ran a Dyna single fire in mine, fully adjustable.
Old 06-04-2012, 06:06 PM
wishbone550's Avatar
wishbone550
wishbone550 is offline
I really like my tc88a
Old 06-04-2012, 06:10 PM
EricM's Avatar
EricM
EricM is offline
TC88 on mine with a custom MAP. Love it
Old 06-04-2012, 06:12 PM
xFreebirdx's Avatar
xFreebirdx
xFreebirdx is offline
The year and model bike is needed before definitive answer can be given...............
Old 06-04-2012, 06:17 PM
jag1886's Avatar
jag1886
jag1886 is offline
I have used a CompuFire for years in my Sporty it's adjustable enough to run my 10.75-1 compression engine with no pinging.
Old 06-04-2012, 07:39 PM
DocUSMC's Avatar
DocUSMC
DocUSMC is offline
its an 03 sportster with 1200 kit in it, originally it was an 883 hugger. It also has a stage 1 carb kit in it.
Old 06-04-2012, 10:59 PM
Logrhed's Avatar
Logrhed
Logrhed is offline
Stage II
I have an 03 XLH 1200.... Single fire Ignition Kits Ignition kits are a great idea!!!.. what I would like to know is now that you have a programable kit ( Ultra to be exact and made by Dyna Tec ) this still leaves us all with a delema...the Bank angle sensor is still going to kick out 5 volts on the backside.... how do/ and what/ do you replace it with to get 12 volts to the ignition so you dont have to bypass it making it another usless piece of junk on the bike. I can interupt at the fuse box with a BAS that puts out 12 volts... but where would I find one??????
Old 06-05-2012, 10:25 AM
DocUSMC's Avatar
DocUSMC
DocUSMC is offline
So with the TC88 basically you arent running off the bank angle sensor anymore? So this module would bolt in and then you would adjust the timing on the module instead of adjusting the timing by rotating the module?
Old 11-14-2016, 01:06 PM
cowboybob56's Avatar
cowboybob56
cowboybob56 is offline
Default Broken ear.
I was replacing the cam seal in the cone. As I was removing the crane hi 4 ignition module and broke off one of the magnetic pickups. Will any othe module, ultima, dyna etc. be compatible with the existing set up?
Quick Reply: Ignition Module Kits
