Removing 48 seat
Removing 48 seat
I read that to remove the seat on my 48 one only needs to remove the rear bolt then slide the seat back to remove it? But unfortunately, that is not working - after removing the bolt the seat still feels as if it is still bolted somewhere and it will Not slide back? anyone know why?
Don't know if it's same as our touring seat(s), but there's a tab on the frame that matches a slot on the seat...can be tight so "wiggle" & pull, but be CAREFUL you don't rake the seat across your rear fender. Might want to lay a towel down & then work the seat off. Once you got it off - reverse order for install...good luck!
I had a hard time removing the seat from my new 48 too. Had to push down really hard and forward at the same time. I almost had to resort to putting the front tire against a wall or wait for someone to hold the bike!!! Finally popped loose though.
Careful you don't slip and scratch the fender/tank or even drop the bike!
