06 xl1200 C Change Handlebars and Speedo Help Please
Hello all..
I want to change my bike handlebars.. and If so, I guess the speedometer I now have will not work on any other RISERS as it seems to be built into the riser...
I am changing:
STOCK 4.5 TANK to Peanut 3.3 tank.
I need advice on what I could buy for a speedometer/gear position module... like the stock, present setup.
I want to go with, I think Drag Bars.
But I do not want them to be really wide...
I am not tall so my reach is NOT wide like some of the bars.
I thought of some of those bars that are in 2 pieces, each having a mounting bracket that is separate for each side. Cannot find any on the net, I do not know what they are called....
At any rate, my new tank is the orange one pictured.
I am going to also include a photo of my stock bike, and speedometer setup.
I am assuming that when I change out the tanks the NEW tank will hit the present speedometer.. if so, I have to change out the speedometer and all...
Thanks for any advice, products I might could use... thanks.
ps, I was hoping for something like in the GREEN TANK photo.. for handle bars.. maybe a higher riser.. but also, need to add on speedometer...and gear position..
I am changing:
cliffd
03-21-2016 11:52 AM
