removing bracket for exhaust install
Old Apr 1, 2013 | 08:12 PM
Simon Lam's Avatar
Simon Lam
Default removing bracket for exhaust install
I am in the progress of removing all the stock pieces from my 48 and adding on the big radius
I am stuck on the part where I need to remove the old bracket and install the new. It said to remove the brake rod from the rear. Am I loosening the end of the brake rod with a torque driver? Its just super tight and I am not sure if I should be doing it cause I feel like its going to snap.
Old Apr 1, 2013 | 10:12 PM
Simon Lam's Avatar
Simon Lam
its super tight as hell. What were peoples methods to getting it off? was there anything else you have to remove beforehand?
Old Apr 1, 2013 | 10:25 PM
cpracing519's Avatar
cpracing519
Yes, you need a torx bit/star bit to remove the brake rod lever. Get a torx bit ratchet bit. (Harbor freight cheap kit)Don't try to use a torx bit style allen wrench. You might end up stripping the bolt. It's on tight, but will snap lose with a quick pull of the correct torx bit and ratchet wrench. Removal of the stock exhaust takes longer than installing the new pipes.
Old Apr 1, 2013 | 10:33 PM
Simon Lam's Avatar
Simon Lam
Originally Posted by cpracing519
yes, you need a torx bit/star bit to remove the brake rod lever. Get a torx bit ratchet bit. (harbor freight cheap kit)don't try to use a torx bit style allen wrench. You might end up stripping the bolt. It's on tight, but will snap lose with a quick pull of the correct torx bit and ratchet wrench. Removal of the stock exhaust takes longer than installing the new pipes.
thank you!
kevdog
Aug 25, 2017 07:53 AM
Smogbob
Jul 23, 2017 05:45 PM
Sad King Billy
Feb 2, 2011 07:56 AM
jterp
May 11, 2007 08:33 PM
