Question about type of paint for gas tank
Old 04-09-2013, 10:04 PM
akhdrider's Avatar
akhdrider
akhdrider is offline
Talking Question about type of paint for gas tank
I got this new 3.3 gas tank, want to replace my original 4.5 tank... but I want to paint my new tank myself.
Anyone out there have any experience painting their tank by spray can? If so, what did you find out will work?
Attached is the tank I want to paint.
I have spray painted with cans a lot before, but not sure what will hold up under gasoline being dripped on it.
Attached Thumbnails Question about type of paint for gas tank-e.jpg   Question about type of paint for gas tank-a.jpg
Old 04-10-2013, 12:34 AM
Robin427's Avatar
Robin427
Robin427 is offline
i do this some times ago, now i do those jobs with a spray gun and comressed air.
i bought the color cans at the local paint shop - they mixed the color and fill it up in spray cans
this cans costs more than the cans from a DIY market but you be safe that the color resists gas and the spray nozzles make a steady surface
you also can use this i used this extra nozzles
the red one makes best result (in my opinion) - mostly mounted at the cans form the paint shop
Old 04-10-2013, 12:49 AM
rquest's Avatar
rquest
rquest is offline
This is not a bad way to go but what ever you do I'd suggest using Urethane paint. It drys fast, won't react or wrinkle if you apply several coats and is very durable.
Old 04-10-2013, 01:30 AM
akhdrider's Avatar
akhdrider
I was told about urethane paint, how it is the best to resist gasoline.. but the only urethane paint I can find in a spray can is...
http://www.repaintsupply.com/pd_2_part_2k_aerosol.cfm
I cannot afford to pay 600.00 to have a tank painted...so I thought I would just do it myself.. maybe not an option..
Thought of buying an Airbrush kit and doing it that way
Has anyone out there painted bike gas tanks using an air brush kit?
Old 04-10-2013, 01:37 AM
akhdrider's Avatar
akhdrider
Talking
Thanks.. but I was told Acrylic paint will not resist gasoline.. must use urethane.. just what others told me.. but I do not see any urethane spray paint on the net.
Old 04-10-2013, 01:44 AM
cavalier2000's Avatar
cavalier2000
cavalier2000 is offline
you could just be really careful when you fill up with gas. When we powder coated my tank the clear said it was fuel resistant..... i don't plan on finding out.
the Japanese gas stations here fill up your stuff for you, and they have a rag with them to make sure fuel only goes where it is supposed to. So far not a drop has hit my tank (cept inside)
So paint it with what you want and be REALLY careful when filling, I bet you wont have an issue.
Old 04-10-2013, 02:37 AM
Robin427's Avatar
Robin427
Robin427 is offline
thats right Acrylic paint dont resists gas...
i didin't regard the word "acryl" and use them for ohter the paints - it will also work
Old 04-10-2013, 04:47 AM
Pixiechitos's Avatar
Pixiechitos
Pixiechitos is offline
Leave it I like it. I did mine with self etching satin black primer rattlecan.
Old 04-10-2013, 07:02 AM
Robin427's Avatar
Robin427
Robin427 is offline
if you not want a glossy paint -- whats about plastdip ..?
i dont know if it's resistant to gas
..but in this case you can remove it easily when you dont like it
Old 04-10-2013, 09:54 AM
Muskie46's Avatar
Muskie46
Muskie46 is offline
I know a lot of guys that use plastic dip and love it. Like Robin said, if you dont like it, you can peel it right off and have your old paint scheme back. I plan on dipping some areas on mine soon. you can find cans at most hardware stores for around $8 or $9.
http://www.plastidip.com/home_solutions/Plasti_Dip
Quick Reply: Question about type of paint for gas tank
