Torque Specs for 1200 exhaust flanges?
Anyone know off the top of their head? I'm getting some popping so I think they need to be tightened up to stop the leak. I'm gonna use the ol cigar smoke method, but I want to make sure I know the specs before I go torquing the bolts down. Thanks boys!
Kevin
Kevin
I've seen a lot of posts about the flange nuts being torqued to 90-120 in/lbs when doing some reading before changing my exhaust. I also found this pdf
http://www.harley-davidson.com/en_US...ts/-J03441.pdf
when researching it. This says to torque them to 60-80 in/lbs. Any idea where the difference comes from? And assuming these values are incorrect, and I need to re torque them to 100 in/lb, is it as easy as loosening the pope support bracket and then tightening them to the new torque or will I have to loosen the entire system first?
stenny
07-11-2013 08:38 PM
Interceptor9C1
Exhaust System Topics
09-08-2011 09:00 AM
