Torque Specs
Old May 5, 2009 | 09:56 PM
VonRizzo's Avatar
VonRizzo
Cool Torque Specs
Hey all...
I'm swapping out my stock exhaust for a set of Hooker Troublemakers and need the torque specs for the exhaust flanges bolts for a 2006 Sportster 883c.
It would be great if someone would kind enough to give me the specs.
Thanx...
Old May 5, 2009 | 10:32 PM
freekdawg1200's Avatar
freekdawg1200
Not sure if this helps any,and I apologize in advance.
It should get you in the ballpark though!
The manual for my 99 1200 says 6-8 ft-lbs at the cylinder head exhaust flanges.
Old May 5, 2009 | 11:32 PM
cHarley's Avatar
cHarley
The spec is 96-120 INCH lbs. Be sure to re-torque after several heat cycles.
Old May 6, 2009 | 07:29 AM
bmxatv's Avatar
bmxatv
not to hijack or anything but can anyone suggest a quality torque wrench?
Old May 6, 2009 | 08:25 AM
VonRizzo's Avatar
VonRizzo
Thanx guys... I would have never thought about re-torqueing them after running them...
I looked around for a good torque wrench and ended up with a Crafstman just because Sears was the only store in my area... I could have ordered a better one on line but needed it right away... But I did get it on sale :-)
Peace...
Old May 6, 2009 | 08:30 AM
VonRizzo's Avatar
VonRizzo
Thumbs up Thanx...
Thank you for the answer. I get the new exausts on Thurs and can't wait for Sat to do the instal...
Peace...
Old May 15, 2009 | 12:08 AM
Tike71's Avatar
Tike71
Would this equate to 8-10 ft/lbs if you're using a ft/lb torque wrench?
Old May 15, 2009 | 12:41 AM
UPSBROWN's Avatar
UPSBROWN
Exclamation
Do the math
:P
Good Question. I was wondering the same. Any mathematicians?
Old May 15, 2009 | 01:06 AM
Tike71's Avatar
Tike71
Originally Posted by UPSBROWN
Do the math
:P
Math's already been done. Just wondering if it's ok to use ft/lbs when the manual calls for in/lbs.
Old May 15, 2009 | 07:48 AM
RATROD HOG's Avatar
RATROD HOG
good call there iron71
