Torque Specs for rear rocker box cover on 2007 1200 Custom
Old 07-24-2014, 07:28 PM
NanaLeigh's Avatar
NanaLeigh
NanaLeigh is offline
Stage II
Smile Torque Specs for rear rocker box cover on 2007 1200 Custom
Hi,
Just recently noticed an oil leak front the left top corner of the rear rocker box cover on my 2007 1200 Custom. I also just recently returned from a trip from NC to Key West and I'm wondering if the leak could possibly be due to vibration loosening something. I need to know what the torque specs are for the rocker box cover so I can check that before I maybe unnecessarily change the gasket. Thanks!
Old 07-24-2014, 07:49 PM
Hal64hd's Avatar
Hal64hd
Hal64hd is offline
There was a gasket design change due to leakage, but the torque value for fthe upper cover is 120-168 inch-lbs NOT FT LBS
Old 07-24-2014, 08:55 PM
Scuba10jdl's Avatar
Scuba10jdl
Scuba10jdl is offline
Here's all the bolts:
Bolts 1: 90-120 inch-lbs
Bolts 2: 10-13 ft-lbs
Bolts 3: 15-18 ft-lbs
The Little bolts on the top rocker cover are 10-13 ft-lbs.
In my manual this is covered under the cylinder head installation section.
Eagle15
12-15-2017 09:07 PM
MURPHCC1
Exhaust System Topics
08-31-2013 09:29 PM
db45
EVO
11-05-2009 12:41 PM
fob_speicher
06-23-2007 08:34 PM
Unibomber
03-06-2007 10:49 PM
Quick Reply: Torque Specs for rear rocker box cover on 2007 1200 Custom
