changing gaskets for rocker cover. ???????
Old Jul 24, 2009 | 02:43 PM
db45's Avatar
db45
Default changing gaskets for rocker cover. ???????
can anyone tel me the toque specs for the rocker cover bolts, and the 4 rocker arm bolts? thanks ahead of time!
Old Jul 24, 2009 | 03:02 PM
t150vej's Avatar
t150vej
10-13 on the 1/4" cover bolts and internal rocker box bolts. (but I usually don't go that tight on the cover bolts unless it has copper washers/hex head bolts) 15-18 on the 5/16" rocker box bolts.
Old Jul 25, 2009 | 03:07 PM
mtnlvr's Avatar
mtnlvr
That's foot pounds if you were wondering.
Old Aug 17, 2009 | 12:24 PM
upright's Avatar
upright
Be sure to go super slow and torque each one a little ata time until you reach spec. If you don't follow a cross pattern you risk squeezing a gasket out of place. Easy does it!
Old Nov 5, 2009 | 12:01 PM
lonm's Avatar
lonm
Stage I
can anyone tell me where the umbrella seals go in evo breather heads. thank you
Old Nov 5, 2009 | 12:27 PM
Knuckles's Avatar
Knuckles
My umbrella seal was on the right side, of the spacer that goes between the rockers and rocker cover.
Old Nov 5, 2009 | 12:41 PM
miacycles's Avatar
miacycles
They go in towards the manifold/carb, the front goes on the left, the rear goes on the right. If you look next to the umbrella valve you will see a small nole abt 1/16" that goes through the plate. If you drill it out to 1/8" you will improve oil drain back.
V_twins
Shovelhead
Jul 11, 2012 12:14 AM
ppablog
Shovelhead
Sep 29, 2010 10:47 AM
flyburch
Nov 24, 2009 04:22 PM
scottdoege
Jan 12, 2009 10:27 AM
98dynaevo
Aug 2, 2008 02:48 PM
