Custom Dynamics LED Turn Signals
Location: In the foothills of southwestern NC - US of A
I really don't know the answer to that, but as far as my '09 Iron is concerned, things were fine until I hooked up one set of LED's - after I did the LED's went haywire. I didn't try it with the rears, but both the fronts and rears are populated with 42 individual LED's so I think both would act the same, or am I hitting the cRaCk pipe?
In the meantine, the incandescent bulbs aren't too bad shabby!
=8^)
elfman, this past week, since my load equalizer's hosed, I changed out my LED's for incandescent bulbs while I wait for a replacement LE, but just for $hitz'n giggles a couple days ago I removed the fronts and threw the Dynamic Ringz back in to see what would happen, and just as I thought, they blinked normal three times, then both the indicators AND the LED's went into hyperflash. After reading on this thread how one guy said his indicators blinked fast but his bulbs didn't, I said to myself, how can this be?
=8^)
=8^)
then try this
turn on the hazards / cycle them on
and let them run for a minute or two, or more to "re-sync" the signals.
shut them off then the scoot - then wait a few seconds like 15 or 20 then try the blinkers
as far as one guy said his indicators blinked fast aka the dummy light
im thinkin its because its a regular bulb for the dummy light it may have something to do with it -- not sure will have to look into that
are your leds all working ? they should act the same yes - unless one of the lights has a few blown led or corroded led then it would act weird ,,
but if you try to do what i said up top -- you should be able to run led in front and regular in back with no problem or hyper flash .. its when you do allllll 4 bulbs you will have problems
ok try again - put the led in front and regular bulb in the rear
then try this
then try this
In regards to your other questions, all the LED's are in picture perfect shape...I poured over each and every one, and found that every single LED is working. I looked for any signs of burn on the individual LED's both on and off, checked the disks, and surface mounted electronics themselves and found nothing, the wiring was perfect with no cuts, bends, or squashes, and all the 1157 style bases were intact and free from corrossion [I always try to use dielectric grease on such connections].
I did have a thought though since you mentioned blinker fluid...I overfilled it the last time and each blinker dripped each time one was used until the level returned to normal. And to make matters worse, I dunno what I did with the last bottle I had and that one took me years to find...that $hit is more rarer than hens teeth and chicken lips combined!
;O)
=8^)
