Rear axle nut after side licence plate holder.
Old 09-16-2014, 05:58 AM
harleyglen's Avatar
harleyglen
harleyglen is offline
Default Rear axle nut after side licence plate holder.
Just after some advice, I have fitted a dk customs side licence plate holder to my sporty iron and noticed the other day while cleaning it that the axle bolt thread does not come all the way through the axle nut but still plenty on the thread. This is because the plate holder is about 6mm thick plus I used the original axle nut washer but the nut cant go anywhere as it is touching the e clip that stops the nut from coming off.
To be honest it has been like that for nearly a year but just curious if any of you that have fitted an axle mounted side plate holder still used the large washer or put the nut against bracket??
Cheers
Old 09-16-2014, 07:54 AM
Scuba10jdl's Avatar
Scuba10jdl
Scuba10jdl is offline
You should drop the washer. That only serves to normalize friction when tightening the nut against the swingarm. With the plate holder there it takes the place.
You should always have 2-3 threads extending beyond the nut threads or you run the real risk of backing off the nut.
Old 09-16-2014, 10:05 AM
kguittar12's Avatar
kguittar12
kguittar12 is offline
this is good info, i just purchased the same license plate holder and was wondering the exact same thing. thanks for posting the question harleyglen!
Old 09-16-2014, 10:26 AM
harleyglen's Avatar
harleyglen
Glad to help kguittar lol, thanks for reply scuba, ok so think im gonna remove the washer to gain some more thread, question now is if the bike is upright on the ground can I remove the axle nut and washer then re tighten nut or will the axle bolt move and have to realign rear wheel again?
Old 09-16-2014, 01:19 PM
Scuba10jdl's Avatar
Scuba10jdl
You can loosen it. If your axle adjusters are not messed with you shouldn't have any movement. Never hurts to check though since it is real quick.
Old 09-16-2014, 01:49 PM
FLS103's Avatar
FLS103
FLS103 is offline
I installed a side mount plate holder from Road6, was told to leave the washer on. So, as advised by Road6, I faced just enough off the axle nut to give clearance. No threads were removed when I faced the nut, just the taper leading to the threads. Gave just enough room....
Old 09-16-2014, 03:20 PM
DK Custom Products's Avatar
DK Custom Products
DK Custom Products is offline
Sponsor
Our brackets are designed to be used without the axle nut.
__________________
www.DKCustom.com
662-252-8828 Voice
662-420-4891 Text & Voice
Support@DKCustomProducts.com
Old 09-16-2014, 03:33 PM
Scuba10jdl's Avatar
Scuba10jdl
Originally Posted by DK Custom Products
Our brackets are designed to be used without the axle nut washer.
Boom! Straight from the source.
But I just had to add that clarification, Natalie. I'm assuming that's what you meant.
Old 09-16-2014, 04:35 PM
cHarley's Avatar
cHarley
cHarley is offline
Damn it Scuba, I was waiting to see how many people bitched next week when their axle backed out at 80 MPH on the slab.
Old 09-16-2014, 07:12 PM
Scuba10jdl's Avatar
Scuba10jdl
Charlie, to you it's Jeremy. From time to time I will take sadistic pleasure in newbies, but I just couldn't let that one go.
It would be almost as entertaining as sitting in the lawn chair on 4th of July weekend at my local boat ramp watching the weekend warriors attempt to back their boats in.
Quick Reply: Rear axle nut after side licence plate holder.
