The Dyno RoomA special room dedicated for Dyno tuning products, troubleshooting and results. All Gearheads and Dyno Operators are welcome here as well as the guys that are new to tuning. Please see the special rules for this section before posting.
Wide band sensors read different voltages than narrow bands, the stock ECM isn't capable of reading them. You need a controller for this. Are you having specific issues?
The question was a simple one. Is the SE tuner compatible with wide band o2 sensors, the answer is NO. In nowhere was it asked "what devices will work with the stock ECM and wide band sensors". If anything is misleading it's your post. Target Tune is not compatible with a SE tuner.
All wide bands need a controller. Not only do you have to deal with the latency of the sensor. You also have to deal with the latency that is added because of the controller.
Sure, Dyno jet can configure your ECM to deal with the controller input but at what cost?
"Dynojet Target Tune runs widebands with a tweaked stock ECU. It works just fine.
Andy "
The red is misleading. How many miles you have you ridden on a TT bike? What have you compared it to? If the answer is zero and none. What are you basing your opinion on?
