The Dyno Room A special room dedicated for Dyno tuning products, troubleshooting and results. All Gearheads and Dyno Operators are welcome here as well as the guys that are new to tuning. Please see the special rules for this section before posting.
HARLEY: VCI drivers failed to install.
Old 01-26-2017, 01:27 PM
ecarbone2051's Avatar
ecarbone2051
ecarbone2051 is offline
Default VCI drivers failed to install.
Trying to install Supertuner pro software. Get the above error. This is a very clean and well maintained laptop. Deleted and restarted several times. Any thoughts?
Old 01-26-2017, 04:06 PM
Sierra977's Avatar
Sierra977
Sierra977 is offline
Received 3,988 Likes on 2,065 Posts
Which version software and what kind of laptop running what operating system?
Old 01-26-2017, 06:11 PM
ecarbone2051
I have tried 2 versions. 10.001.0000 and 10.002.0002. I'm using win 7 pro on a custom built Puget Systems 64 bit laptop.
Old 01-26-2017, 06:20 PM
ElectraJim's Avatar
ElectraJim
ElectraJim is offline
Do you have local admin rights on the PC? Have you ever installed any other software on the machine?
Could always try right-clicking on the setup or what ever and choosing "install as administrator". Just a thought.
EDIT: Another thought, make sure all your Windows updates are up to date and temporarily disable any anti-virus programs that are running.
Old 01-26-2017, 07:02 PM
ecarbone2051
tried all those accept stopping antivirus. i'll try that. The rest of the software loads and runs, but it will not communicate with the tuner/bike.
Old 01-26-2017, 07:06 PM
ecarbone2051
didn't help.
Old 01-27-2017, 10:09 AM
Sierra977's Avatar
Sierra977
Turn off popup blocking? That works with some of my problem boxes
Old 01-27-2017, 10:53 AM
jbarr1's Avatar
jbarr1
jbarr1 is offline
Many have forgotten to turn on the run switch on the handlebars when bike won't connect. Make sure you are using the correct data connector as well.
Old 03-10-2017, 08:35 AM
jkbandit's Avatar
jkbandit
jkbandit is offline
Stage I
Ecarbone2051 did you resolve your issue? I am having the same problem . download software and ran the .exe to install. will not install VCI drivers but will install program.
thanks
Old 04-15-2017, 04:30 PM
Concord01's Avatar
Concord01
Concord01 is offline
4th Gear
Default VCI Fails to Update
Has anyone found a fix for this? I have windows 10, installed v 10.002.0002 from Harley's website and the software runs, communication is established, lower left icon lights up green and i can read the bikes vin and ecm p/n, but cannot update the VCI.
Quick Reply: HARLEY: VCI drivers failed to install.
