TTS: TTS: Anybody familiar with using the Spark Control vs Engine Temp tables?
I use spark temp correction (engine) and IAC temp correction. If you are getting spark activity above 112. Take away from STC table. Practical application is running hard through turns in lower gears and speed. Bike heats up due to ripping through gears with less airflow compared to 90mph down the highway tank to tank. IAC temp correction is usually a transition from just off a period of idle. Pulling away from a stop sign. IAC temp change rate is much higher. This table adjustment is rare.
Vtune3 does address Spark Temp Correction along with the main spark table. I look at it as tuning the engine for best performance available for the condition over taking performance away. Before we tuned for worse case scenario, and it was good enough for all.
Bob
Gordon61 (02-03-2017)
