Inner Cam bearing failed
Hello, new to the forum, just got done taking my 06 Road King Classic apart due to loss of oil pressure. Inner cam bearing failed and roasted the oil pump. Looks like all the parts stayed in the cam chest, or are trapped in the oil filter (I hope) Any pointers/tips before going back together? Haven't done a runout on the crank yet, but plan to go back with hydraulic tensioners, new cams, oil pump and cam plate, & inner bearing of course.
Thanks
Thanks
Drop the oil pan and clean it out. You might need full flush as well. One lifter failed on my 09, ESP would only cover replacement of the lifter, oil pump and cam support plate, no flush, etc.. Look what came out in the oil when I changed it the first time. Not good. ESP runs out Dec-2015 so will see if it goes again before then.
Thanks
Thanks
Another suggestion...replace the lifters if they are the original ones...use a high quality lifter, don't scrimp on this! I suggest S&S or JIM's, but I'm not a Harley mechanic...some guys like Gatormans, I have no experience with these, but the ones I mentioned are ones that I KNOW are good for the distance...but don't trust the ones ya got unless they've already been changed out...bad lifters are pretty common...generally no way to tell that they're going bad...unless, of course, you hear that 'ticking' as the engine runs...
