Smoothed Tour Pack
Smoothed Tour Pack
After doing a thread search with no luck, I thought I'd ask to see if anyone has done or has any info on pulling the luggage rack off of the HD tour pack lid. If so, do you have pics? What did you use to fill the holes where the luggage rack bolted to the lid? I also want delete the antennas since I listen to XM or my iPod. Do people just use a castle nut or is there someone that sells a stud cover for the antennas?
I am going to be removing a rack from a tour pak lid soon. The tour pack is after market, the rack is HD oem and I want to put in on my new Ultra. Ace Hardware sells small plastic plugs and I am just going to use those and silicone on the backside. I'll just make someone a good deal on the TP cause the rack has been removed.
If you do not mind paying you can get the plastic holes filled and primed. This way you can not tell holes were ever there. I had it done a few years ago. I think the cost was around $150 filling and repaint. you could not tell where the holes were when they got done. Just don't be in a rush. Do it when their business is slow.
I am referring to plastic welding.
I have a bit a chrome acorn nut theme going with my 09 FLHP so I used them on the T Pak as well. This is a shot of the area where the wrap around back rest would have been mounted...I have replaced it with the chopped back rest and needed to cover the holes. When I pull the luggage rack off of the top I use 4 of the acorn nuts there too.
I did see at one time a shop that had some nice chrome spears that mounted in the holes left by the removed luggage rack. I think they were about $70. The looked nice however I wasn't willing to pay that much. I looked but could not find the link...maybe someone else knows what I am referring to.
EDIT: Google is powerful...a search on "tour pack chrome spears" revealed this. I do seem to recall a version that were specifically made for the T Pak removal that bolted into the existing holes...this kit appears to be stick on which makes it difficult to get the rack back on.
And when the luggage rack is removed:
Received 70,440 Likes
Your dealer has the plug holes for the antennas.
As far as removing the rack goes you can find hole plugs at Lowes or similar for next to nothing, very cheap.
Notice the black dots, rubber plugs.
That way if I really wanted to use the rack that I still have I could.
It looks much cleaner with out it though.
