Stage one air filter
Old 11-10-2014, 06:50 AM
95ci springer's Avatar
95ci springer
95ci springer is offline
Default Stage one air filter
I was wondering if removing the gas tank on a 2015 FLHTK is needed to remove the connector mounted on top the throttle body? I don't have a manual yet and don't know the proper method to remove the tank.
Old 11-10-2014, 09:22 AM
Keithhu's Avatar
Keithhu
Keithhu is online now
Received 5,365 Likes on 2,619 Posts
You mean the throttle body support bracket? I would buy a kit that doesnt require removing it, like the Fuel Moto one.
Old 11-10-2014, 09:28 AM
heritageblue2013's Avatar
heritageblue2013
heritageblue2013 is offline
Are you looking at adding a high flow air filter kit? Might want to call Fuel Moto or another large parts store and inquire if you need to for the type of system you want to add.
Old 11-10-2014, 09:59 AM
95ci springer
The screamen eagle one I purchased to keep the stock outer can says to remove it in the instructions.
Old 11-10-2014, 10:02 AM
Keithhu's Avatar
Keithhu
Yeah, can you return it? The Fuelmoto one doesnt require you to remove it.
http://www.fuelmotousa.com/fm117-449...m117-449c.html
Old 11-10-2014, 10:07 AM
95ci springer
Not sure I can return. I opened all the bags and put the sticky gasket on the housing already.
Old 11-10-2014, 10:08 AM
95ci springer
My bike is a 2015 limited.
Old 11-10-2014, 07:31 PM
SafetyMan's Avatar
SafetyMan
SafetyMan is offline
I removed my tank.
I have never had to before, but those bolts were ON there.
Removing the tank on a '14 or '15 is literally a 3 minute job. And VERY simple if there is not much fuel in it.
Old 11-10-2014, 07:50 PM
oc1014's Avatar
oc1014
oc1014 is offline
You can do it without removing the tank. The two mounting bolts take a 3/16 Allen head. It takes 10 minutes to remove them with the tank in place.
Old 11-10-2014, 08:18 PM
xhere's Avatar
xhere
xhere is offline
Originally Posted by SafetyMan
I removed my tank. I have never had to before, but those bolts were ON there. Removing the tank on a '14 or '15 is literally a 3 minute job. And VERY simple if there is not much fuel in it.
What he said, quicker to remove the tank in a few minutes than to fight it..
Quick Reply: Stage one air filter
