how can I tell if my battery is about to die
With the engine running the volt gauge is reading the charging system and all system loads, its not reading the battery. When the engine is not running the volt gauge is reading the battery but the ignition must be on so its also reading the load from the lights. Put a full charge on the battery, let it set for a couple hours and then check with a multi meter, let it set over night and check again to see if it drops. Get it load tested. Cold weather does play a part in the slow cranking.
Most auto parts stores will load check your battery for free to help determine it's health.
On the other hand, many batteries fail due to a single cell shorting out due to deposits building up till they touch the bottom of the cell. Then it is all over, and you will get no warning.
Choice is to run it till it dies, or replace it when you feel uncomfortable.
Everybody wants to get the most life out of their batteries possible, but nobody wants it to go out on a major trip or inconvenient time.
Here are some nice high output high perf factory activated maint free agm batteries that last a long time and are good quality at great prices for quality lvl and power put cca wise.
I THINK STOCK OEM SPEC BATTERY IS 385CCA AND THE HIGHER OUTPUT BATTERIES I LISTED BELOW ARE IN THE 400cca,500CCA,600CCA RANGE .
SOME ARE BELOW $100 INC SHIPPING & THE REAL HIGH OUTPUT BATT'S ARE A BIT OVER $100 INC SHIPPING.
THESE ARE SOME OF THE BEST BANG FOR YOUR BUCK PRICES I HAVE SEEN ON BATTERIES FOR OUR BIKES WHEN IT COMES TO REPLACEMENT HIGH OUTPUT HI PERF FACTORY ACTIVATED AGM BIKE BATTERIES.
Scott
1) http://www.batterymart.com/p-Big-Cra...L-Battery.html
2) http://www.tristatebattery.com/etx30...ery-p-982.html
THE NEXT BATTERIES ARE ON EBAY,SOMETIMES WHEN I PAST EBAY LINKS HERE THEY DON'T WORK SO I ALSO LISTED ITEM #'S TO SEARCH IN EBAY TO FIND THE BATTERIES IN CASE LINKS DONT WORK.
3) http://www.ebay.com/itm/ETX-30L-Powe...315552?vxp=mtr
ebay item 321599315552
4) http://www.ebay.com/itm/321596830525...84.m1436.l2649
ebay item # 321596830525
5) http://www.ebay.com/itm/281432489841...84.m1436.l2649
ebay item # 281432489841
6) http://www.ebay.com/itm/121429861963...84.m1436.l2649
ebay item # 121429861963
7) http://powersportbatteries.com/more-...nk-etx30l.html
Scott
So I went to the stealership today. Battery is fine. 14.5 is fine while runnning. 11.5 to 12 with ignition on. And 10 or higher when cranking it. He said even 8 would be fine. And added that cold weather will naturally make it turn over slower. Made a about 7 stops today. No issues . Keeping it on the tender .
rocket science is not required
This is the correct way to test the battery without rocket science.
Digital voltmeter required.
Measure standing voltage of battery after motorcycle has been sitting overnite. Should be 12.6 v or higher-if not replace battery. 12.8v is a 100% battery
If the standing voltage is good:
While monitoring the battery voltage start motorcycle watching the voltmeter when you strike the starter.
If voltage falls below 10v replace battery.
