Battery Talk And Tips
Old Dec 12, 2005 | 08:45 PM
HDF Tech's Avatar
HDF Tech
Default Battery Talk And Tips
Selecting the Proper Battery
It's easier than you think to buy the wrong battery for your vehicle. Unless your current battery is definitely the original equipment, you're taking a chance by not double checking before you purchase the new battery. You can search for a certain battery, but there are a few general rules you should know before you search. - If the battery for your vehicle is sensor-equipped, remember to replace the sensor at the same time you change the battery.
- Never swap a Maintenance Free battery for another battery unless the Applications book says it's OK.
- When given the option of several different batteries for your vehicle, choose the one that will give you what you want performance-wise. It's up to you.
- Always make sure you have the right battery before you charge and install it. Save yourself the hassle (and money) of having to buy another battery.
FAQ'S
Why should you charge your battery once a month?
When not in use, a battery discharges on a daily basis sometimes up to 0.5-1%. This rate of discharge increases when the climate is warm. To make up for this loss from disuse, a boosting charge should be given once a month.
What is sulfation?
Discoloration of plates with white lead sulfate crystalline deposits may occur when the battery has been left for a considerable time in a discharged condition. It can also occur as a result of the plates being exposed to air due to low electrolyte level, or when a new battery is filled with acid and stored without being charged. This phenomenon is called sulfation. Once plates have been sulfated, the activity of the affected area is permanently impaired, and the battery may not be restored to its original capacity.
Why do the winter months seem to bring more battery problems?
The main reason is that batteries have to work so much harder in cold weather. Engine oil is thick, so engine cranking effort is much higher. Also, a battery's charging efficiency decreases in cold temperatures. In addition, gasoline does not vaporize as readily in the cold, which means that even more battery cranking effort is required.
What is the normal charge rate for a battery?
Naturally, batteries of different capacities require different charge rates. Generally, a battery should be charged at a slow charge rate of 1/10 its given 10 hr. capacity.
How do you determine whether a battery has been charged?
The following characteristics will tell you if a battery has been properly charged:
1. The specific gravity of the acid is over 1.275 (conventional type batteries only).
2. Maximum voltage output across battery terminals can be maintained at constant level for two hours.
3.Open circuit voltage is stablilized @12.7v or higher @ 6.3v or higher for 6 volt batteries.
How should a battery be maintained?
Good battery maintenance should include the following:
1. Always keep the acid level between Lower and upper lines on front side of the container (conventional type batteries).
2. Do not let the battery stand in a discharged condition.
3. Charge battery once a month.
4. When motorcycle is stored over 30 days, plug in a Yuasa automatic battery charger to maintain a proper storage charge.
5. Keep battery top clean, dry and free of dirt.
6. Clean battery terminals to prevent corrosion. Inspect vent tube, ensuring that it is not bent, twisted or clogged.
7. Protect the battery from strong impacts or shocks.
I was told by some old timers that if you leave a battery on the ground or a concrete floor it will ruin the battery. Is this true?
That is something a lot of "old timers" say. The reason they say t
FenderGuy53
Jan 17, 2025 01:12 PM
FurryOne
Electrical/Lighting/Alarm
Jan 24, 2020 07:33 PM
t059736
Feb 24, 2018 10:30 AM
TestFlyer
Jul 6, 2009 03:07 PM
jacktana
Jul 7, 2008 10:12 PM
