Disconnect battery?
Old Jul 7, 2008 | 07:03 PM
jacktana's Avatar
jacktana
Default Disconnect battery?
Well I ran the battery down and need to put on a charger. Manual says disconnect battery to charge. Do you all disconnect? I thought the Tenders that many use have pigtails directly to the terminals, so there would be no disconnect to charge using them? How about just pulling the maxi-fuse when charging to disconnect?
Old Jul 7, 2008 | 07:31 PM
Thumper26's Avatar
Thumper26
Default RE: Disconnect battery?
They're just trying to prevent you from shorting the battery out with alligator clips.&nbsp\\; You are right, the Battery Tender has pigtails directly to the terminals, so there would be no need to disconnect to charge - just be careful with those clips!
Old Jul 7, 2008 | 09:40 PM
jdvorchak's Avatar
jdvorchak
I use the battery tender on 3 bikes and my cars. Never have disconnected a battery to charge unless it was already removed from the vehicle. I think thumper is right. Product liability and all.
Old Jul 7, 2008 | 10:12 PM
Dorkman's Avatar
Dorkman
The battery tender isn't a charger, per say.&nbsp\\; It will only maintain a battery that has a sufficient charge, and bring it back to peak, then maintain it at peak over an extended period.&nbsp\\; To bring a dead battery back you need a battery charger that can deliver low amps and shut down (or you shut it down) when the battery is sufficiently charged.&nbsp\\;
FenderGuy53
Jan 17, 2025 01:12 PM
alfalfa
Mar 13, 2009 03:55 PM
vetto
Sep 25, 2008 07:17 AM
nutmagnet
Jul 7, 2008 07:23 PM
HDF Tech
Electrical/Lighting/Alarm
Dec 12, 2005 08:45 PM
