Starter Switch Elimination
Old Dec 18, 2005 | 02:46 PM
HDF Tech's Avatar
HDF Tech
Default Starter Switch Elimination
Here's a nice simple way of elimination some wiring on a custom or even a stock bike, makes it just mechanical and no electrical wiring... HERE
From Skip (pococj)
And if you have an older bike with the solenoid on the primary, this guy makes a mechanical switch for them... HERE
Skip was kind enough to point out that there is a mistake in this article. The author says it can be used on all Evo starters, but it can only be used on those with the solenoid that is parallel to the starter motor, not the older Softails with the solenoid on the left of the primary. It's s'posed to fit 1991 - 2005 (don't know about 2006) factory & aftermarket starters, except for Compu-Fire.
NO PCKL
Sep 7, 2014 07:57 PM
75hdxlh1000
Aug 10, 2012 09:09 AM
williamfrog
May 28, 2012 09:27 AM
head
Sep 30, 2010 03:08 PM
bensoniq
Jun 18, 2010 06:52 AM
