Sporty Starter
Old Jun 17, 2010 | 11:47 AM
bensoniq's Avatar
bensoniq
Stage III
Default Sporty Starter
Starter keeps running when motor is on, can you help ?
Sometimes just when key is turned to on position....
Thanks.
Old Jun 18, 2010 | 03:14 AM
trmac's Avatar
trmac
Big Kahuna HDF Member
Probably either the switch is bad or a short in the wiring.
Old Jun 18, 2010 | 04:07 AM
dbleagle's Avatar
dbleagle
Right off the top of my head I would say there is corrosion built up in the starter button and the contact is sticking.
Open up the switch housing and use a wire to jump the switch to see if the start stays engaged that way. It is a process of elemination... could be the starter... but I would start with the simplest things first.
Charlie D.
Old Jun 18, 2010 | 06:52 AM
WRAITH's Avatar
WRAITH
Remove the starter relay located on the fuse panel. Take the relay to a local auto parts store and get a replacement. Plug the new relay in and try again.If the problem remains unchanged, it mite be the switch.
novaiiman
Apr 14, 2015 04:22 PM
75hdxlh1000
Aug 10, 2012 09:09 AM
oldmsocko
16
Oct 13, 2011 04:41 PM
rickydog
Jul 6, 2011 04:22 PM
sbarnes489
Oct 27, 2010 02:32 PM
