Compensator Lifespan
Ive always wondered what percentage of bikes that are higher mileage (50,000+) and have not had issues with the compensator. I know that some don't have issues and some guys go through 3 in 10-20K miles. There must be something that is a common denominator in the latter group that has not yet been identified. Crappy metal, poor design, and lack of lubrication would apply to all, yet 100% of bikes don't run through them like a case of oil. Just wondering....
I had an 07 Road King with 50,000 miles on it when it needed a new compensator and main transmission bearing. I traded it in on a new Limited instead of paying for the repairs (est $1700 with 50k service). Much happier with the Limited
Question, what does the compensator do? I'm not that mechanical. I can change the oil and replace voltage regulator, etc. but I stay out of the engine and tranny.
I wondered the same thing. Forums are always full of the people that have all the problems that get posted for the public to see. But what about the thousands of touring bikes that never experience premature comp failure. I do agree that it is a poorly designed part for the long run, but there are lots of variables that will wear the comp out faster than normal. I often wonder if many of the premature failures have a lot to do with personal riding styles. The comp is ultimately wear item that eventually needs maintenence. It's a poorly lubricated item and it's metal on metal design wears out.
I don't see why harley won't change the design 9f the comp to a 4 spoke gear and 4 cam ramps. This would give more surface area for the comp to spread working forces out to reduce wear. Or ditch the comp for a solid gear set and design a new clutch pack with a spring dampening system much like the clutch in a car
