Who runs gear oil in their transmission?
Old 01-14-2015, 09:29 PM
SWThomas's Avatar
SWThomas
SWThomas is offline
Default Who runs gear oil in their transmission?
I'm currently running Syn3 in all three holes of my 2004 RK FLHRI. I saw a bunch of Facebook posts in a group thread of guys saying they run gear oil in their transmission. Some were running 75W-90 and some 75W-140.
Is that too thick of an oil for the trans on a Harley? What are you running in yours?
Old 01-14-2015, 09:31 PM
dawg's Avatar
dawg
dawg is offline
Received 2,969 Likes on 1,718 Posts
I run 75/140
Old 01-14-2015, 09:36 PM
qtrracer's Avatar
qtrracer
qtrracer is offline
I have run Formula+ , Redline Heavy Gear Oil with Shock Proof, and I am currently running Amsoil 75-110 Severe Gear. Can't tell the difference between any of them. Next time I will run Lucas Gear oil 75-90 just for fun.
The following 2 users liked this post by qtrracer:
00FattyT (07-03-2021), NiteOwl (07-05-2021)
Old 01-14-2015, 09:40 PM
soft 02's Avatar
soft 02
soft 02 is offline
Received 4,570 Likes on 2,888 Posts
Only people who like there transmission use gear oil.
The following 3 users liked this post by soft 02:
NiteOwl (07-05-2021), radarlove (08-04-2021), Tecinc04 (09-09-2022)
Old 01-14-2015, 09:42 PM
BackRoader's Avatar
BackRoader
BackRoader is offline
Red Line Shockproof here also. Not sure on weight, but man its some thick sheet.
Old 01-14-2015, 09:46 PM
mkguitar's Avatar
mkguitar
mkguitar is offline
I use gear oil in my Panhead ( ball bearings in cages)
My evo and my twincam use HD Primary +
why? they were designed for it , the bearings, the gears, the shear resistance and the gaskets.
I tried redline once- no improvement to the straight cut gear whine
a "thicker" oil will fill some gaps, but may not flow as well into tiny crevices, it will provide resistance ( which makes heat)
Mike
Old 01-14-2015, 09:48 PM
QC's Avatar
QC
QC is offline
Received 19,786 Likes on 9,863 Posts
Valvoline 75W-140 Full Syn. here. Went from Redline Shockproof to this. I like this better.
Old 01-14-2015, 10:21 PM
KnarleyHarley's Avatar
KnarleyHarley
KnarleyHarley is offline
Getting ready to change the oil in mine. Dealer did the changes when I bought it last July with 10k on the clock, not sure what they used other than Dino in motor. But I'm going to add SuperTech full synthetic 75w-140 gear oil as I'm a firm believer in "if it has gears, use gear oil"!
In fact I'm changing all 3 fluids to synthetic. Hoping for a less "clunky" shift, but if not it will still have fresh fluids...
Old 01-14-2015, 10:32 PM
SeaZund's Avatar
SeaZund
SeaZund is offline
got my tranny apart right now (2006 5 spd) replacing 5th gear; going back together with Amsoil Severe Gear 75W-110 (synthetic)
Shane Grimstead's Avatar
Shane Grimstead
Shane Grimstead is offline
I'm using the Spectra 6 speed synthetic transmission oil and my dad is using the belray 75-140 synthetic gear oil. Both run very well with no issues. Both bikes are 2015 SGS's.
Quick Reply: Who runs gear oil in their transmission?
