Baker announces new compensator kit
Maybe this is old news..dunno...but just received an email about it...
BAKER Compensator Kit
Return to carefree riding with the BAKER Compensator Kit for 2007-Later Big Twins!
Our kit includes:
34-Tooth Compensating Sprocket
Motor Extension Shaft
Cam Slider
Spring Cup
Retention Bolt
Part Number: 630-67K
Retail Price: $399.00
Our kit includes:
Cam Slider
Spring Cup
Retention Bolt
Our kit includes:
Cam Slider
Spring Cup
Retention Bolt
Our kit includes:
Cam Slider
Spring Cup
Retention Bolt
Joe,thanks for the heads up on the Baker comp!
I assume the smaller twin cam 96ci my 09 FLHTCU has is still considered an 07 or later big twin like Baker states the kit fit,correct?
I think the comp on my 09 FLHTCU with only 10k miles on it is going bad because it makes a loud bang/clunk sound when i hit the starter button to fire it up which i have read here is a sign of comp going bad.
Original owner of the bike changed the primary case oil at 1k miles ,then 5k miles and i just changed it at 9,700 miles when i got it along the changing motor & trans oil too.
The primary case drain plug was loaded with grey slimy metallic type contam and oil from primary with just under 5k miles on it looked very dirty/dark like it was loaded with contam from metal wearing which is likely the comp going bad.
scott
There still being tested right now and have only been sent out to a select few right now and not expected to be sold to the general public for another month or so. You can call and pre order. Also you have to have the new style SE rotor, so if you have a 96" with the old style you will need to purchase a rotor from harley.
I pulled these picks from another site.
Received 47,791 Likes
