Hardwire to Accessory Switch
Hi, Gang
I have a 2013 FLHR and would like to hard wire an iPhone5 charger (the cell will be mounted on the handlebars) to the Accessory Switch on the nacelle. Does anyone have a link or directions (or advice) for accessing the switch wires and connecting to the switch?
Thank you in advance,
Rudy
Rudy
how about you wire into the unused position light wiring ?
this is "on" when the bike is "on"
the wires are attached to the headlight wire loom...orange/wht is hot, black is ground.
the acc switch is wired to the acc plug which is under the seat...so if you want something on your bars, you'll be running wires up under the tank
Mike
Mike
Here are the instructions for the power outlet attached to the accessory switch. You can also get a dual one as well. I would go with the advice above if you wanted it permanent and then you wont have to flip the acc switch on and off.
http://www.harley-davidson.com/app-c...ts/-J06026.PDF
Or you could get one of these and use your existing accessory harness.... if you're not already using it....
http://www.leadermotorcycle.com/weat...rt-for-harley/
Received 1,506 Likes
You don't have to hard wire anything. I use this on my '13 King https://www.3brpowersports.com/products.php . It's the 4-pin connector for the Harley and it's waterproof. It plugs into the accessory connector under the seat. I ran mine along the main harness to the bars under the bar clamp cover.
Then I use this USB plug to power and charge my Garmin GPS. I use the iPhone USB plug to charge my iPhone. https://www.3brpowersports.com/produ...d_Band_USB.php
Everything is all plug-n-play.
Added: Looks like Leader MC now sells this from the link by SWThomas above, but 3BR Powersports makes them.
I would need to run an iPhone lightning cable with lighter adapter directly to the accessory outlet. So I guess I have the answer to my question. Thank you everyone for your helpful suggestions. Now I just need to decide upon speakers. J&M Handlebar Mounted?
Not sure where you got that info from but it's not 100% accurate. I have a bunch of lighting cables that aren't apple and they charge my phone just fine. Some of the cheaper ones won't allow sync or music to be played over them but they will charge the phone.
I don't know if you have an iphone5 or newer, but the way they program the operating systems really gets you by the short hairs! There aren't any after-market charging systems/wires that are compatible with apple products anymore (you can plug the wire in, but the phone will sense that the wire is after-market and will not allow the phone to charge). Apple has become as much of an tyrannical empire as Microsoft (if not more).
I use aftermarket as well. I buy most of my cables from monoprice.
http://www.monoprice.com/Category?c_id=112&cp_id=11222
Or Amazon's brand, Amazon Basics.
