cams to replace se255
so let us start with what I have now..
2011 roadking classic
103
se255
V&H power duels
SE type AC (from fuel moto)
PCV
otherwise stock motor
I am thinking I want to replace the cams (I was in the cam chest
and noticed some wear on the lobes).
I like the power curve of the se255s so would like something
similar
would like to keep the stock push rods and not do head work/springs
or change the pistons...
Is there something better out there that I can "drop in"..that will
give me power in the same areas as the se255..
103
se255
V&H power duels
PCV
similar
Here is a thread that is currently running - it has some good Dyno sheets for some different Cam's they've tested.
I kinda leaning towards the Woods 222's
https://www.hdforums.com/forum/new-r...fuel-moto.html
My service department is pushing the torquester cams instead of SE255. Has been for a few years now. I think this is it:
http://tmanperformance.com/Cams/tr-5...-models-chain/
At one time I was interested in this mod myself. I have SE255s now instead. How did you handle the tune?
I just installed a set of Woods TW0222's in my 96. I'd picked up set of used 222's here on forum looked brand new. Loaded a Fuel Moto map and fired it up late yesterday afternoon. All I can say is WOW it really woke this boy up from previous stage 1. I ride in 2500-4000rpm range and I am very pleased. Great low end-midrange torque and nice little cam tone accent at idle .
tune
I have a power vision, but also have a copy of the stage 2 download from hd. The timing and VE tables are really really close. What do you have now for a tuner? I was in Charleston this past weekend, LOL
My first question is - is the bike not running correctly? What caused the lobes to wear? Are they worn off?I have run SE cams in the past and not had or heard of any issues quality wise. Reason i ask - if you have an issue that caused the lobes to wear on the SE cam and do not correct it- it will do the same thing to the new cam. If you like the 255 I would stick with it and fix the issue. If you are just wanting to change to a different grind - proceed. Just make sure you change the lifters. Twin Cams use roller lifters. There should'nt be that much wear if any...
