How many quarts of oil in each hole at service
Old 05-30-2015, 01:24 PM
A206Driver's Avatar
A206Driver
A206Driver is offline
Default How many quarts of oil in each hole at service
I ask because I was charged for 7 quarts syn3 at 5k service. I know it only calls for oil and filter at 5k. So how many for just oil and filter and how many for the other holes?
4emmalah (08-02-2020)
Old 05-30-2015, 01:44 PM
Beak's Avatar
Beak
Beak is offline
Not sure about 7 quarts? Usually motor with filter change 3 to 3.5 quarts. I put in three and check the dip stick and adjust after running. If they used Syn 3 in the transmission it holds about 1 quart. Primary, if wet holds a little over a quart, 38 oz I think is what my manual says.
Not sure that adds up to seven quarts, but maybe they spilled one
Old 05-30-2015, 01:46 PM
TheGrandPoohBah's Avatar
TheGrandPoohBah
TheGrandPoohBah is offline
Received 2,524 Likes on 1,421 Posts
Generally, 4 for the engine, 1 for the tranny, 1 and a few ounces in the primary.
"6 and a bit" total - generally.
I only put 3 and a half in the engine, 6 total works for me.
As always, consult your manual...
Old 05-30-2015, 01:51 PM
ricktherocket's Avatar
ricktherocket
ricktherocket is offline
What does your manual say your machine holds?
Mine is 4qts w/filter in motor, 1.4qts in the primary and 1qt in the transmission. 6.4qts total which translates into 7 at the dealer.
Old 05-30-2015, 02:22 PM
A206Driver's Avatar
A206Driver
OK, then it is possible for 6 plus some and charge for seven. Thanks for the replies.
Old 05-30-2015, 02:31 PM
ngshop's Avatar
ngshop
ngshop is offline
Now this is how it really works with the tech doing your service. The partial quart the tech needs he uses from a previous customer and keeps your additional quart. Over a short period of time he has a collected a bunch of new unopened quarts of oil. I know this how... my buddy has a friend who is a dealer tech and he manages to sell my buddy multiple case of customer paid for Syn 3 oil, cheap. I do my own services on a 2011 Roadglide Ultra and use a little less than 6 full quarts. By the way 4 quarts in the motor is a little excessive.
Old 05-30-2015, 02:36 PM
qtrracer's Avatar
qtrracer
qtrracer is offline
3.5 for the engine, 1 for the trans and 1qt and 6 ozs for primary. So total of 6 should do the job. The engine does not take 4.
Old 05-30-2015, 02:46 PM
hemi1300's Avatar
hemi1300
hemi1300 is offline
Does 3.5 quarts apply to the 103 engine as well? Coming up on my 5k service on 14 sg, manual states initially fill with 3 quarts then perform cold check, and states it holds 4 quarts.
Old 05-30-2015, 04:08 PM
ricktherocket
Well then my owners manual and my service manual are both wrong then.
The specs for my 2009 is 4qts w/filter crankcase, 1.4qts (44.8oz.dry) primary & 1qt trans.
Old 05-30-2015, 04:51 PM
qtrracer's Avatar
qtrracer
qtrracer is offline
Fill it to where you guys want. I pretty much don't care. I've changed the oil too many times to argue with you experts. Put 5 qts in, LOL
Quick Reply: How many quarts of oil in each hole at service
