Road Tech Zumo - NIM Problem
I have a Road Tech Zumo 660LM mounted on my bike and connected to the radio through the Harley Navigation Interface Module. It has been working fine for the past year since I installed it. All of a sudden I no longer get voice directions through the speakers. Music plays fine through the Aux connection and the music mutes when the Zumo wants to give me voice directions. The Zumo works fine when not on the mount and the voice comes through the Zumo speaker.
Anyone had this problem? Any ideas on how to troubleshoot the problem to see if I have a bad NIM or bad wire connection (I have visually checked all the connections and can't see any problem).
Installed on 2010 FLHXSE.
Thanks, Rick
Thanks, Rick
Do you have any troubleshooting tips or wiring diagrams that I can use to see if my NIM is defective or a connection has come loose.
This was their response:
Thank you for contacting Garmin International. I would be happy to help with this today. Unfortunately the NIM cable is an exclusive Harley Davidson part, we do not have any installation instructions or diagrams for those cables. To have that cable checked out, your best bet would be to have the dealership that installed it take a look at it for you.
Who needs Garmin when you have this forum. The alcohol did the trick. I had wiped both the pins and the contacts on the back of the Zumo with a clean Microfiber cloth without success. Added alcohol and that fixed the problem. Thanks TriGeezer.
When I was searching the forum for a possible solution I saw that some had that problem where the switch wasn't in the "speaker" position. I don't have that switch on my bike. I think I read that it is only on bikes that have a CB or intercom.
Nice scooter
Thanks, Rick
Thanks, Rick
