Grommet on Stator Wire leaking oil - help
I have oil leaking from the grommet on the stator wire that passes through the crankcase. Looking at the service manual, there are 2 "sealing o-rings" and 1 "retaining o-ring" on the grommet. There's not a lot of leaking oil, but a drip or 2 every time I park the bike.
Is it possible to replace those 2 sealing o-rings by pulling the grommet out, disconnecting the wires from the voltage regulator, replacing the o-rings and stuffing it back in the crankcase?
I'm trying to avoid taking the whole left side of the engine apart just to replace a couple of o-rings.
Any ideas?
Any ideas?
Make sure you cleaned to wires and the housing very, very, very good. Use brake cleaner. Then clean it again.
RZRob (05-04-2021)
