Anyone using Ohlins #2-#2 (a) shocks by Howard
I'm wanting to keep my current shock height of 11.5 inches. (Bitchin Baggers). Howard told me these shocks are 11 inches. Does anyone have any experience with these shocks? My only concern is clearance issues, but I was told many riders are using them. Thanks in advance!
I have the #3-1, which is lower but with less stroke. Me and the missus go about 330lbs on the SG with another few lbs in the bags. After reading the instructions and listening to Howard and getting them dialed in I cannot say enough good about them. Ride better, sit lower, bike seems more firmly planted, especially on some of the washboard roads, better handling really noticeable on a sneaky decreasing radius turn.
And no clearance issues at all and believe me, I've kept a close eye on it. At least for the first 500 miles or so.
When it comes to shocks, Howard is truly the man. If he says you won't have a problem, you won't have a problem. If you do, he will fix it.
I purchased those exact shocks a few months back and you will not be disappointed. They are by far one of the best upgrades I have done to my bike. It actually rides like it should now without you having to tense up when you see a big bump comming. Howard does a great job and I highly recommend!!!
I bought them (2A) about 3 years ago..They are everything people say they are...They are great and a lot better shocks than the factory airshocks and sit about 1/2 inch lower than factory......I am 5'7" with ohlins 2a shocks, A new seat (C&C seat it sits you lower by about a 1 1/2} and boots that have a 1 inch heel I am flat footed....I have a 2010 streetglide with a 16" wheel on the back...A 18" rear wheel will be about a 3/8 higher than a 16......Ohlins shocks are Great shocks.....
Going to said it again...if you are are wanting a very good shock for riding (not talking about bar hopping) these are very good shocks...But to lower the bike to be flat footed you will need to do several more things. Lower sitting seat and 1 inch heel boots, Most boots are 1/2 to 3/4 heels...
The negative about these shocks is, you cant adjust them for riding two up and then you ride solo..the ride is harder...but my wife rides with me 95% of the time...so when I ride solo the bike rides like it has the air shocks on it but about 25% better....hope this helps
