Help with Cam and C/I Selection
This is my 2001 RK, MM, 95" Screaming Eagle Motor Build which dynoed 95Hp 103 Tq...
I want to build a Bigger, More Hp/Tq Motor...
Using my SAME EXISTING HEADS ONLY...
What Is A Bigger, Suggested Cam and How Big C/I Can I Go...
S&S 510G
SE Flat Top Pistons
9:7:1 Compression
.030 Head Gasket
82 CC Combustion Chambers
1.900 Dia. Intake Valve
1.610 Dia. Exhaust Valve
.590 Lift Beehive Valve Springs
7MM Valve Stems
195/205 Exhaust Port Flow
265/270 Intake Port Flo
S&S 510G
SE Flat Top Pistons
9:7:1 Compression
.030 Head Gasket
7MM Valve Stems
Maybe I did not do a good job of asking my question.....
I want help on finding a Bigger Cam that will match to the EXISTING Head Build that I already have..
Then I will do maybe 110/117 C/I Cylinders to Increase Motor Size...
I know with the MM FI, I have Limitations, but believe it or not I have a very Stable working FI System, that has given me 27,000 Problem Free Miles.... I have a DynoJet, PClll, Fuel Controller installed.
Please help me with a More Better, More Powerful Cam than the S&S 510G, that I am presently using, Which will work with my EXISTING HEAD BUILD...
