Road Glide Fairing Bracket Question
I'm interested in the same conversion. I can't answer your question, but I suspect the answer is no. That said, follow this link and look up the parts numbers for yourself. If the part number is the same, or if it's not, you'll have your answer. http://partsfinder.onlinemicrofiche.....asp?make=hdmc
Not quite the answer your looking for.
But I can add this info for you. IF you plan on adding lower fairings with vents (or lower fairings w/ speakers) you will NEED 2010 - 2013 fairing brackets.
Since your SG is a 2013, "IF" I were in your boots, I still would be looking for a 2010 - 2013 Road Glide bracket.
I'm assuming your going with the old Road Glide Fairing and not the "Rushmore" fairing.
Good Luck with your project!
YB
YB
