shifts gears, won't move
Old May 21, 2024 | 09:34 AM
jrobb2855's Avatar
jrobb2855
5th Gear
Default shifts gears, won't move
looking for a little help.
2008 Ultra Classic. I was heading home from work. My battery light came on for about three minutes and then went off, voltage charge gauge went back up to 15 volts. I drive for about another 25 miles and then I no gears. The clutch lever felt fine and it seemed as if it was shifting thru the gears, but it wouldn't move.
Old May 21, 2024 | 09:40 AM
GOGOBECK's Avatar
GOGOBECK
So the engine runs and you can pull in the clutch and shift gears, but letting out the clutch doesn’t engage the drive?
Turn the engine off. Put the bike in gear, does the bike roll freely?
Old May 21, 2024 | 09:44 AM
jrobb2855's Avatar
jrobb2855
5th Gear
It does roll freely, yes.
BrandonSmith's Avatar
BrandonSmith
Active Streak: 30 Days
Battery/voltage issue plus clutch issue?
Something is broken on one of the main shafts.
Surely the primary chain didn't break... you'd hear that.
Old May 21, 2024 | 09:47 AM
jrobb2855's Avatar
jrobb2855
5th Gear
So you don't think the two could be related in any way?
Old May 21, 2024 | 10:04 AM
memphisharley's Avatar
memphisharley
were you rolling along and the bike came out of gear or had you stopped and tried to take off.
Old May 21, 2024 | 10:05 AM
jrobb2855's Avatar
jrobb2855
5th Gear
I came to a stop light and then tired to take off again.
Old May 21, 2024 | 10:06 AM
BrandonSmith
The exact opposite. I think they ARE related.
The electrical system (stator and rotor) is attached to the main shaft that spins with the engine at all times.
The clutch is located on the secondary shaft but is connected to the main shaft via the primary chain.
If the bike is not moving with engine speed, there is a disconnect between the secondary shaft and the primary shaft. That could be the secondary shaft itself or its gears, clutch, primary chain, or the main shaft or its gears.
Since you're having charging issues, I'd suspect something on the main shaft is the culprit, since that is where the charging system is located and what drives the movement of the rest of the system as well.
Old May 21, 2024 | 10:08 AM
GOGOBECK's Avatar
GOGOBECK
It’s gonna be something in the clutch assembly. I’m assuming the Final drive belt is attached and intact.
I don’t think your battery issue is related.
Old May 21, 2024 | 10:09 AM
jrobb2855's Avatar
jrobb2855
5th Gear
Thank you for the info, I will take the primary cover off and do an inspection.
