A better way to tighten clutch jam nut...with pics
Old 09-21-2015, 09:21 AM
Talldog's Avatar
Talldog
Talldog is offline
Default A better way to tighten clutch jam nut...with pics
First off, I can't take credit for this, I saw it on the Fuel Moto site. Just thought I would share.
Tightening the jam nut when you do a clutch adjustment has always been a PITA. I have always used an 11/16" offset wrench. It worked, but you really had to be careful that it didn't slip off, or that the wrench wouldn't scratch the primary cover.
I've seen where some guys take a socket and weld a nut on the end, but this is an easy alternative.
First off, buy an 18mm Spark Plug socket. I recommend this one I got from Amazon, but you can buy from whoever. Just make sure it's a 6-point and not a 12-point.
Wilmar Performance Tool W38168 Wilmar 3/8-Inch Drive 18mm SP Socket - Automotive Accessories - Amazon.com Wilmar Performance Tool W38168 Wilmar 3/8-Inch Drive 18mm SP Socket - Automotive Accessories - Amazon.com
You don't have to do this, but the socket isn't an exact fit, so to give it as much "purchase" as possible, I ground the end a little to eliminate the chamfer inside the opening.
Stick your Allen wrench thru the center, and use a 13/16" wrench, and you're all set!
Old 09-21-2015, 09:26 AM
RevBlk's Avatar
RevBlk
RevBlk is offline
Thanks for sharing.
Old 09-21-2015, 09:50 AM
beary's Avatar
beary
beary is offline
Yes, that is how I do it. Works good.
Beary
Old 09-21-2015, 10:42 AM
Ragtop's Avatar
Ragtop
Ragtop is offline
Received 1,011 Likes on 576 Posts
thanks for posting
Old 09-21-2015, 10:48 AM
Roadblock_MN's Avatar
Roadblock_MN
Roadblock_MN is offline
Thanks! That should make it easier this week!!
Old 09-21-2015, 11:09 AM
qtrracer's Avatar
qtrracer
qtrracer is offline
The jam nut is 11/16" not 18mm as TD stated, I know an 18mm will work as I have used it. A spark plug socket in 3/8" drive in the correct size of 11/16" is available online. Jim's also sells($$$$$) a tool with a handle already on the 11/16" socket, if you have the means it's pretty cool. The tip is appreciated Talldog.
dyna rider's Avatar
dyna rider
dyna rider is offline
Default Socket
This seems to be a fix for a problem that most people don't have.
I haven't had any problem using an allen wrench and a offset wrench.
Old 09-21-2015, 11:10 AM
qtrracer's Avatar
qtrracer
qtrracer is offline
If you have a VPC only the socket will work.
Old 09-21-2015, 11:13 AM
Roadblock_MN
I have done that in the past as well. But it is still a little bit of a struggle...
Old 09-21-2015, 11:22 AM
MNPGRider's Avatar
MNPGRider
MNPGRider is offline
Tall dog, where the heck were you earlier this summer with this tip? I've already got sockets like that!
I wanted to make sure everything was right when replacing my "from the factory funky clutch cable," so I looked all over town for an 11/16" offset, but ending up buying a "no longer made in USA Craftsman (see the Craftsman tool thread) ) entire set of offsets that cost me $39, just to get one wrench, to properly and positively set my clutch after the cable replacement.
Jeesh, man, be a little more timely with your tips, would you?!
(All in good fun.....wish I would have thought of it!) Anyone wanna buy a set of Craftsman offsets?
Quick Reply: A better way to tighten clutch jam nut...with pics
