IDS questions on 07 Ultra
My uncle is going through some issues with his 07 Ultra with the IDS upgrade. He's had it installed for quite some time and I think it just needs rebuilt. My question is, will the OEM 2009+ setup work on a 07 model...I know their are some internal differences like 1-piece isolator vs. 6 pieces. But as a whole system will the new replace the old? Thanks
I've done it but it was more of a winter project. It was well worth the time and effort and the cost was less than you would think.
Link to my thread:
https://www.hdforums.com/forum/touri...-a-how-to.html
Link to my thread:
Had one put on right after taking delivery of my 2007 Ultra. The bearing wasn't pressed in correctly, probably not seated right, and the bearing needed replacing at about 7,000 miles. That time, the shop had the correct bearing press tools, and it lasted until 32,000 miles, when the bearing wore out again. When the shop ordered the part, they didn't realize that the part number for an 07 was different from the others. Its because the 07 has a smaller diameter axle than 08 and later. It sure made a difference though, and worth the headache.
