Valve stem caps
RE: Valve stem caps
TIRE CHECK
[align=left]
[/align][align=left]
With TireCheck, you will never have to say, Does this tire look low to you"? You will be able to see at a glance when your tires need air. TireCheck is a tire pressure indicating valve cap which can be used on virtually all cars, SUVs, light trucks and motorcycles. One size fits all for tire pressures between 20 - 42 psi.
TireCheck indicates when there is a pressure loss of 2 - 3 psi. This unique product increases fuel economy and extends the life of your tires.
Inflate each tire to the vehicle manufacture's recommend tire pressure. Simple installation, just screw onto existing tire valve and replaces existing valve cap. TireCheck will display a pressure loss by a red indicator flag above the green in the clear plastic sight-glass. The red indicator shows if the tire pressures on the same car or different cars within the 20 - 42 psi range. Each time you remove and re-install TireCheck you will see an all green indication in the clear plastic sight-glass. TireCheck automatically sets itself to the new pressure. Sold in sets of 4.
All Green...Tire Pressure OK
Any Red...Check Tire Pressure!
[/align]10/14/05
QTY
(ENTER #)
ITEM#
PRODUCT NAME
PRICE
SHIPPING
TC60
TIRE CHECK/SET OF 4 CAPS
$19.95
$5.00
gregm
10-13-2007 11:14 PM
