CVO Garage Door Transmitter on Regular Touring
Old 04-04-2016, 09:56 PM
vhrock's Avatar
vhrock
vhrock is offline
Default CVO Garage Door Transmitter on Regular Touring
I know CVOs all come with Garage Door Opener Transmitters already wired up in the fairing. Can anyone tell me if I purchased a used garage door opener transmitter that came off a 2015 touring CVO, for example, could I install it on a 2015 FLHXS and couple it with a receiver? Would it work, or are they 2 different animals? Thanks
Old 04-05-2016, 05:27 AM
msocko3's Avatar
msocko3
msocko3 is offline
I don't see any reason why it wouldn't work, make sure whoever removed it from the CVO wasn't some back yard hack. You'll also need the HD receiver for it to work.
load97 (04-05-2016)
Old 04-05-2016, 06:00 AM
load97's Avatar
load97
load97 is offline
Yep, what he said. Make sure and get the HD receiver thats tied in to the garage opener.
Old 04-05-2016, 06:11 AM
Ultraboy105's Avatar
Ultraboy105
Ultraboy105 is offline
Why is it being sold???
Old 04-05-2016, 07:33 AM
msocko3's Avatar
msocko3
msocko3 is offline
That's a good question, not many guys would just cut something out of their harness just to sell it, I know I wouldn't.
Old 04-06-2016, 06:55 AM
vhrock's Avatar
vhrock
vhrock is offline
Thanks for all the replies so far. Yep, and I knew there was a need for he receiver as well as the transmitter. This is another reason I'm asking, the pictures look like there was no "cutting from their harness," as you can see in the pics, it looks simply unplugged from their harness with no original splicing into the wiring as the add-on part instructions say to do from Harley. For CVOs, did Harley make a nice neat plug n play interface, whereas for those of us who don't have a CVO have to splice wires? Thanks
Attached Thumbnails CVO Garage Door Transmitter on Regular Touring-image.jpeg
Old 04-06-2016, 07:27 AM
msocko3's Avatar
msocko3
msocko3 is offline
You might want to check and see if the 14 and later touring only require plug and play. I know my 06, the 10 I used to have and my dad's 09, all were in need of splicing in.
Old 04-06-2016, 07:33 AM
ROCKOUT Rocker Products
ROCKOUT Rocker Products is offline
Sponsor
Received 1,628 Likes on 1,176 Posts
My '15 Limited Low had no connector like that.... had to splice.
For ROCKOUT information & purchasing please click the links below...
__________________
NO, they DON'T all do that!
Also on amazon.com...
Old 04-06-2016, 07:58 AM
load97's Avatar
load97
load97 is offline
Sorry Bud. Need to splice. I made a thread about how to do it with pictures if you search my history. It would be about 1 1/2 years ago.
Old 04-06-2016, 12:18 PM
mkguitar's Avatar
mkguitar
mkguitar is offline
or look at the diy mods sticky above- over 300 posts on using a GDO...from adding switches, to adding relays ( like flick the high beam or turn signal or honk horn etc etc).
a less expensive solution
Mike
Quick Reply: CVO Garage Door Transmitter on Regular Touring
