Help reading wiring schematic on accessory connector
I am adding a heated backrest from the new tourpak I just received. I am using the switched accessory connector under the seat. I have the Y harness connected to it for the heated rider and passenger seat already with an open deutsch connector that I want to use. The wires that connect to the used tail of the y connector are orange and black. Makes sense- pos and ground and work fine. However the wires from the deutsch that connect to the other tail of the harness are orange and red/y. They dont look like they would work according to the schematic, but I'm not an expert at reading those. See pics of the schematic with a close up of the accessory pic and a pic of the deutsch y harness. Which is the ground? Does that circuit even look right for an accessory? Any help would be MUCH appreciated !!!
The accessory plug has a pole that is hot all of the time and pole that is hot only when the switch is on.
Hook up a test light turn switch on test ,turn of test and you will know witch is witch.
The orange comes on with the accessory switch on the dash.
That's what it looked like to me also. So what I don't understand is that when you connect the HD Y harness to the accessory plug, it is supposed to give you 2 accessory plugs from one. How does it use the O/R and R/Y wires for an accessory circuit? If you look at the Y harness, one side (two pins of the deutsch) connects to O and Bk and the other side connects to the O/R and R/Y. Makes no sense to me. What is even the purpose of having those wires terminate on an accessory connector?
I can splice into the current side of the harness that has the O and Bk wires and is switched but I wanted to use a deustch for ease of removal and a much more watertight connection. I just don't understand what the other side of that Y harness is supposed to provide with the O/R and R/Y.
It's for versatility. You may have an accessory that you want on with the ignition switch or something you want on with the brake lights. There are a lot of accessories out there.
Guys, thanks for the thoughtful input. I hadn't thought of the run/brake circuit for a tourpak add'l light bar, etc. I will just make my own y harness to the switched side of the current y harness. Have the deutsch connectors and the amp pull won't be significantly higher. Love this forum.
You can find places on line that sell Deutsch connectors and pins on line. I think Electric Depot is one. Then you can make your own Y connector.
Thanks. I've got a terminal supply about a mile away from my office and they sell every connector known to man. They've got these 300 amp deutsch connectors the size of my Dragula exhaust!!
